My Alfadiag has a fault reading of a knock sensor. Does anyone know where it is located on my 1999 2.5 V6? I cant see any diagrams of its position.
thanks mate, was getting a bit worried there when i got no reply. That normally means i am going to pay througt the roof at my local. Ha ha
V6 knock sensors are either end of the block hidden in the 'V' under the chrome inlet tubes. Swines to change :(
Oh hell, i know what two you are talking about. Do you have to remove the inlet tubes to get to them?
They're a pain. Crome tubes out, followed by fuel rail and injectors. Crome tube mounting plates off. Remove thermostat housing (a ****) followed by the long black pipe that runs between the heads and then you'll see the sensors.
Good luck.
Hi ho, hi ho, it,s off to the local i go!
As said mate although not sure where they were the fault did clear after a new lambda in mine, it may be thats whats needed?
