Hi there,
Can anyone advise if there is anything on the throttle body that wears or breaks that will cause idle problems and cutting out at junctions.
This happens when car is hot or cold. Cleaned throttle body the other day and initial idle is good but still cuts out
cheers
From most of the posts I have seen it could well be the MAF (near air filter) try unplugging it and going for a drive , may idle roughly but should not cut out if it's what is causing a problem(I stand to be corrected!)
Normally with air flow meter probs you notice a remarkable loss in power as well on the v6 engine, if you haven't got this then I'd be changing the lambda
