I seem to have bought the most complicated tensioning tool out there. A pair of stilsons would have done the trick (& far cheaper) but I'm scratching my head how this actually works. Anyone used one? (It's a Laser 3791 tool)
Cheers Pud, I was going to get order one of these plus some other bits, but Totally Alfa (Gary) is not well at the moment - so the website says. The functionality for buying has been removed from the site.
He has his own version of the laser tool on there as well....I'll try & work it out somehow!
Do you have any scrap metal around Murray? I have one of the tools Dan quoted, so if needed you could make your own with some dimensions
Thanks Taylor, I'll keep trying to work this tool out for now...ha.
BTW: Got both engines & boxes out over the last few days so now have uprights avail if still needed; they are in an 'ok; condition - don't look too pretty but top bearing spinning free and no knocking.
Just to tie up this thread. Here's the tool in situ; finally worked it out :rolleyes:
The bottom is anchored into the alternator bolt position. The nut on the long bolt that's visible is then tightened/loosened to set the tension on the belt. Good thing is it holds the tensioner in precisely the correct position as you torque up the tensioner bolts.
I reckon it would be a definite struggle to use this with the engine in the car, plus it's £50. Unless you're working on engines out of the car I wouldn't recommend this tool.
I know there is no belt on in the photo!
  • Like
Reactions: Taylor93
