7
Hi All,
Need help! :D I haven't received the documentation for the 155 just yet. And I am away from my car. I just need to know if there is a cam angle sensor for the 155 2.5 V6? :confused:
I'm putting in an aftermarket EFI in the car (goodbye Air Flow Meter ).
Can one of the V6 owners please help? (Wrinx, AndyMac ? ) :D
J
Discussion Starter #2
ok then..yours seems only to have a TDC sensor located down on the front pully.
7
Really??? Did you check the parts CD or workshop manual? Man that sucks. Thanks anyway though.
The thing is the 155 V6 has no distributor, it has a coil pack, so it must have some way of determining which cylinder is at TDC. I was told it has a cam angle sensor.... arghhhhh!!!
The Crankshaft sensor tells the ecu which cylinder is at TDC
The Camshaft sensor is only fitted to some cars to ensure the Cams don`t get out of line due to a slack or badly adjusted cambelt which could cause piston to valve contact as the clearances are run very tight on modern engines (i think)
