My newly aquired spider v6 has serious issues!
I knew there was a bottom end noise so went about investigating and recognised dmf noise. Having been "reliably "informed that the v6 bottom end is bomb proof as long as oil hasn't been lost I went about fitting a gta flywheel and clutch ( not easy but did it on my own on the drive with subframe on). Old clutch was shot but on starting the old knock was still there worsening as she warmed and particularly on reving overrun. Bottom end!
So I dropped the sump (again not straightforward but doable ) I found one big end pummelled with shards of shell in the sump. The bearing had spun and so I tried cleaning it up and fitted new shells as the journal looked serviceable. I was wrong! Didn't last 5 minutes!
So what to do? New crank, new rod or rods? Or replacement engine?
I'm tempted to put in a replacement engine from autolusso or the like and rebuild the original collecting parts over time but I'm undecided. Any input would be welcome and if anyone knows the whereabouts of any reasonable parts or replacement 3.0 engines it would be much appreciated.
I would love to get her running for some of the summer.
Tim
Tim
