Hi All,
When doing my Thermostat and rear bank plugs the other week I was having difficulty getting the inlet pipe back on to the throttle body. It just wouldn't sit straight and when I tightened the jubilee clip it would just pop off again. It is pretty much rammed on now but probably not sealed well and contributing to my occasional lumpy idle.
I noticed on a few threads that the battery should be 175mm, I measured mine at 190mm so I am guessing this is way too tall.
My battery has 570CCA and 60AMP capacity. Is this correct? I notice all my dash lights go out when I crank the engine and the starter is a little slower than I would expect. Is this normal Or is it about time I got a new battery?
Thanks,
Thanks,
