Would appreciate your advice on this guys..
Basically, i would like to tuck my GT out of harms way in my garage and keep its mileage down as its currently on the works commute every day.
So i found this very tidy Seat Leon 1.4 petrol, 68000 miles, FSH, 2003 vintage at a used car specialist, took it for an 8 mile test drive, went over it with a fine toothcomb and could only find a slightly worn drivers seat base and worn rear tyre so agreed a deal and picked the car up yesterday.
Anyway, purchased said car and about 12 miles up the road at about 65mph there was a slight misfire and the engine warning light started flashing, only to go out again shortly after. I stop for a rest break and a few miles later it starts misfiring again and the warning light reappears, i then nip over to my local garage who hooks it up to his diagnostics and finds misfire on cylinder 3 and coil pack issue so clears the fault codes and tells me to return if the warning light comes back : says it could be the EGR valve.
I suppose you can guess what happens, about 3 hours later its back on , intermittently misfiring then revving cleanly, and currently the yellow light is staying on.
I decide to contact the used car garage and to his credit, he doesn't immediately tell me to foxtrot oscar, but to get the fault investigated and if not too expensive then he will foot the bill, but if its going to run to several hundred then he will see about a refund.
The issue is, i really like the car, its great on fuel, will be perfect for the work commute, but will it need endless parts thrown at it to fix the fault, so i'm undecided, do i cut and run or try and persevere with it in the hope it can be swiftly cured ?
I suppose the next step is to take it back to my local garage for further investigation.
Your thoughts please guys
Regards, Tony
Regards, Tony
