I'm at the mechanic with gearbox out and he gave up please help. Trying to fix backplate actuator seals, symptoms: oil leaking out from backplate between the position sensor, selespeed fluid in gearbox.I have taken off the back plate, changed the 2 visible seals. How do I dismantle the vertical shaft to clean and change seals??? I removed the c clip now what?
