1 - 12 of 12 Posts
Hi all,
i need a 3/4 of a 2.0 liter 8v engine. Or some parts from it.
apperantly the alfa factory in italy does not sell piston with +0,10. I would have to by everything standard and change it. Total cost $3500 aprox.
maybe someone in central or south america know someone selling this, it would be cheaper to ship. But ALL are well come.
thanks for all help.
N
Nicholas
Have you tried sourcing non Alfa pistons from your local engineering company????
They should be able to get some pistons for you and will be considerably cheaper than buying Alfa ones
Hi Speed Freak,
i just talked to wrinx over MSN and he suggested the same thing.
Since i am NOT very technical, could you explain to me, what i need to do..what info should i hgive the people. I think there is 1-2 companies that do racing pistons, maybe they can help me.
N
Nicholas
All you should need to give them is the spec of the piston your wanting and you car details they should have them listed
ie if you want pistons that are +10 thou oversize tell them and they should be able to locate some for you
Try cleaning the crown of the piston to see if theres a size stamped on it
It all depends if your just replacing the standard pistons or having the block re bored if your getting re bored the engineering people who are re boring it should be able to get you the pistons and rings
Hope this helps
Just talked to my engine guy. He suggested using ^sleves^ and then the original pistons.
What do you think?
N
Wrinx there seems to be a typing error as the 1.8 and the 2 litre have the same bore and stroke 2 litre should be 84mm x 90mm. eek!
Discussion Starter · #10 ·
Well,
if you look at the 1994 June version of the 2.0 8V, they have the bore at 84x90..maybe it was changed.
N
Nicholas, just took a look at the parts disc and a piston & liner can be ordered from Alfa, but there are 2 types C-mod part no. 60778558 and D-mod part no. 60778832. eek! eek!
1 - 12 of 12 Posts
