1 - 10 of 10 Posts
Can anyone in Alfaland help.
My 155ts is spitting out its coolant from the reservoir cap when its only hitting 90 degrees c. The coolant/water is not boiling so its not a overheating/temp issue has anyone got any ideas?
Banned
if it was the gasket you'd be overheating terribly. Which you say you're not.
Sounds like there is just too much in it! Remember, it's warm outside so it starts off at a higher level already. Logically speaking.
Sounds like head gasket to me if its pressurising the cooling system and its passing the headertank cap it will have gone.
Cooling system pressure is around 15 psi to pass the cap the pressure release valve is opening and combustion chamber pressure is all that can make that happen.:cry:
If you fill the resovoir to the top it still wont pass the cap at normal cooling system operation.
The radiator has a bleed screw on the back of it. If you release it (when cold) then you may get a hissing of air coming out.. Top up the coolant (the level will have dropped) and try running the beast again and see what happens. If you get the same symptoms and more air in the radiatore, then your gasket has been mortally wounded and needs to come off the pitch.
I wouldn't put too much emphasis on it "not overheating" - it could be that there is simply no coolant around the temperature sender, so it's just returning the temperature of the air around it. You need to bleed the system and make sure there's no air in there, then see what happens.
My guess is that there is air in the system, from a blowing gasket, and that it's pressurising the system enough to force coolant out. There's probably an airlock in the rad' but enough coolant still circulating (bottom of the rad hot, top of the rad cold) to keep the engine from overheating.. but this won't last.
Sooner or later, you'll have all air and no coolant.. then it really will overheat (though you won't see it because the sender will be reporting the air temperature, not the coolant). Warped head, scuffed pistons, melted water pump.. you get the idea. :eek:
Ralf S.
1 - 10 of 10 Posts
