can people educate me on the subject please?
are they a modification that can be made on their own, or do they need to be done in conjunction with other mods?
is it possible (for example) to simply fit the injectors from a larger displacement engine to increase the fuel you're getting into the engine?
Phil
You'd need at least a re-map afterwards to cater for the extra fuel being put into the engine. Have you had a rolling road done then saying that you've got det due to running lean? Upgarding the injectors isn't a normal way of extracting more power unless you've carried out everything else(mod wise) and your injectors are beyond about 85% of their capacity.
Cheers,
Mark
on a 1.6 the injectors will not be a problem anyway, but if it is, you'd better get an adjustable fuel pressure regulator. More fuel pressure means more fuel being injected
