I (finally) got the new bottom arms on and replaced the a/r bar drop links. I also fitted the Eibach springs while I was at it too. One thing that sprung to mind (no pun intended) was are the front springs seated properly at the top? Do they need lining up or do they tend to sit as intended without too much hassle?
I just want to make sure they are sitting right as I didn't line them up really, just located the bolts holding the strut to the hub and made up the top nut on the shock absorber then slackened the spring compressors.
well.. the rubber top cap unit bit thingy is slightly moulded so the end of the spring hits a 'full stop' on the moulding.. that's about all tho.. just tighten it up and away ya go!
j
