1 - 2 of 2 Posts
HI guys
Well after taking my 147 to the dealer and having the examiner hooked up the error given was something about the pump relay failed.
We had a look at the psi of the sele system to find it was fluctuating all over the place 36psi to 70 psi !!
Apparently its normal range is 40-50 or so.
So now we think it is the pressure sensor on the box or the accumulator ,now the bad news is that if it is the accumulator they will have to apparently replace the whole actuator because they dont know how to repair it, quite silly cause it is easily removed from the actuator unit......
pressure sensor should be around R300 (30 pounds)
Lets cross our fingers :rolleyes:
Does anybody know if the accumulator is repairable ? maybe some extra info on it ?
Thanks Guys
quote
Thanks Guys
unquote
you cannot open it and if you could how do you get it closed !
1 - 2 of 2 Posts
