Hi all,
Hoping someone can help me make sense of fault code readings from ABS system of Alfa 156 2.0 1999.
Used Unidiag kwp71 software, connected pin 7 to 1 in obd interface and used 'auto' setting as recommended and set ECU setting to 0x20.
First fault code reading I got was:
Read diagnostic faultcodes :
Bytes received: 08 00 01 F1 14
DTC: 0x08 = 8
state : 0
type : 0x00 unknown
condition1 : 0x01
condition2 : 0xF1
counter : 0x14
Cleared faultcodes and took for short spin and ABS light returned.
Read faultcodes again:
Bytes received: 08 00 01 F4 14
DTC: 0x08 = 8
state : 0
type : 0x00 unknown
condition1 : 0x01
condition2 : 0xF4
counter : 0x14
Am I right in thinking the fault code is 8??... as dosen't correspond with ABS fault code info I could find.
Obviously something wrong but don't know how to make sense of data.
Have spent a few hours reading posts but still none the wiser so decided to start new thread. Would appreciate any help,
Thanks.
Can confirm DTC is the fault code.
Finally found comprehensive list of of ABS fault codes for 156 '99.
Will list them here for reference:
X=0x05 Valve relay
> > X=0x06 Incorrect number of teeth on phonic wheel
> > X=0x08 Front LH speed sensor not feasible.
> > X=0x09 Front LH speed sensor in O.C.
> > X=0x0A Front RH speed sensor not feasible.
> > X=0x0B Front RH speed sensor in O.C.
> > X=0x0C Rear LH speed sensor not feasible.
> > X=0x0D Rear LH speed sensor in O.C.
> > X=0x0E Rear RH speed sensor not feasible.
> > X=0x0F Rear RH speed sensor in O.C.
> > X=0x10 Battery voltage
12-diagnosis - Start / End (Starts / Ends with the diagnosis)
> > > > 14- Rear RH speed sensor not feasible.
> > > > 16-valve defect magnetic front LH /
> > > > 17-valve defect magnetic front RH /
> > > > 18-magnetic valve defect behind
> > > > 19-defective safety valve relay
> > > > 25-False Übetragungstaktung-gear wheel defektr
> > > > 26-magnetic valve defect behind LH
> > > > 27-magnetic valve defect behind RH
> > > > 28-defect discharge valve Magne front RH
> > > > 29-defect discharge valve Magne front LH
> > > > 31-defect discharge valve Magne rear LH
> > > > 32-defect discharge valve Magne rear RH
> > > > 35-pump defects Rückforderpumpe Relaikreis
> > > > 37-Broken Bremslichtschalter
> > > > 39-Broken Vordersensor LH
> > > > 41-Vordersensor not connected LH
> > > > 42-Broken Vordersensor RH
> > > > 43-Vordersensor not connected RH
> > > > 44-Broken rear sensor LH
> > > > 45-Behind sensor is not connected LH
> > > > 46-Broken rear sensor RH
> > > > 47-back sensor is not connected RH
> > > > 48-battery voltage is not okay
> > > > 55-defect control unit
> > > > 56-reading with "ausblinken" failed
> > > > 74-lot impact on warning in the instrument block
Why dont you try Fiat ECU Scanner? It is much better than Unidiag, and has detailed descriptions of the ECU error codes...
