Hi all,
I want to keep my GTV on the road and when I finished using it as my daily car (hopefully in the next 12 months) she will go back to being a weekend/occasional car. to that end I want to deal with some of the rustly bits underneath.
Jacking points on the sills bent and rusty.
Forward wishbone mounts - surface rust
Rad support
Misc small marks underneath
Check inaccessable spots (saw one spot in the engine bay where the joint between two panels has a line of Ricky rust around it)
The Rad mount and the Front wishbone mounts I could probably do in a Farmyard shed that I can use and if push really came to shove I could get access to a garage ramp on weekends but the reality is that since December, while I did replace the Radiator, I have not had any time to do much since.
So - any recommendations for someone to do the job for me?
Thanks,
NF
Watching this thread with interest (also in Cork) ... have a GTV too that needs to be sealed-up this year underneath... Lots of surface rust, but hoping there it nothing too bad..
Hi Cathal,
I don't have much in the way of surface rust (and neither does the car), so I got a quote of 150 for cleaning up under the boot - dealing with the sils and the front wishbone mounts. I may get them to do the rad mount at the same time - although I have a fancy to do that bit myself simply beacause I can..... if that makes sense!
I have another name to check out and I'll update this when I have the second one.
Ned.
