This is a cross post form the uConnect 6.5 firmware update topic.
Disclaimer: I can not be held responsible for any damages to your uConnect, Car or your hair falling out from running this modification.
That being said, if you do have a problem please contact me and I will see if I can help you fix it.
For all those people still on v17.07.55 or older uConnect 6.5 firmware I offer you a “jailbreak”, you can now update your maps to the latest versions. I have to warn you though, the process can take a lot of time!
For those of you who have updated your uConnect to v17.35.41 or v18, I am still working on how to update those, FCA / Alfa changed the locks with that update!
For a Full EU update, if you follow my instructions fully, it will take approx. 4hours during which time your uConnect must remain powered on. This time can be greatly reduced by only updating the country or countries you need, or if you are feeling brave, skipping Step 1.
Files / Items needed:
uConnect 6.5 running v17 or older firmware -Now support Fiat and Jeeps too!
At least 8gb USB Drive preferably with a flashing led light so you can see file access
Files from
MEGA
Stage 1 – Backup your files
Prep:
Download:
1 Magic -Alfa pre UPD.zip -For Alfa
1 Magic -Fiat & Jeep pre UPD.zip -For Fiat / Jeep
2 Backup.zip
Process
1. Download and expand “1 Magic.zip” and “2 Backup.zip”
2. Copy the content onto the root of the USB drive
3. Start car and let uConnect boot up (wait approx 5min for full boot up)
4. Plug in and WAIT, the uConnect will not appear to be doing anything but if you are using a USB with a light you should be able to see it flashing with file activity
5. After some time, in my case it took 1h25 to complete this stage, it should popup a window about there is a update that you MUST answer NO to
6. Pull USB, and power cycle the uConnect*
After that you now have a backup of all the system and map files we are going to change on your uConnect.
KEEP THEM SAFE!
Either use a second USB for stage 2, save the backup folder to your computer or if your like me and use a 16gb USB stick you can leave it where it is.
I have now uploaded copies of the official EU Map Packs from (A) 2013, 2015 and 2017 that should function as a backup or official upgrade for anybody needing them.
Stage 2 – Modify your uConnect
Prep:
Download:
1 Magic.zip --You should already have this if you completed Stage 1
D FEU Custom 2021v1.zip --FullEU
Or
A EU 2013 Original NQEU2012Q4.zip --Stock 2013 Maps, Original EU Release
A EU Update 2015 HMEU2014Q2.zip --Going back to stock with 2015 Maps
A EU Update 2017 HMEU2015Q4.zip --Newest Original Map files released 2017
Process
1. Download and expand “1 Magic.zip” and “D XX Custom 2018 HN….zip”
3. Start car and let uConnect boot up (wait approx. 5min for full boot up)
5. After some time, depending on “D” file used - If country only pack approx. 15min if full EU then approx. 2h, it should popup a window about there is a update that you MUST answer NO
If all gone well you will now have a uConnect 6.5 with updated maps!
There may be other little problems for the rest of the EU but I am unable to test them.
*To Power cycle:
Either remove key, lock car, wait 10min, unlock and restart)
Or use engineers menu to reset the uConnect (Press Radio, More and Browse until menu pops up, scroll down to Reset Radio, answer YES)
Files from
MEGA
Prep:
Download:
2 Backup.zip
Process
KEEP THEM SAFE!
Prep:
Download:
Or
Process
*To Power cycle:
