Hi guys. I have had my Giulietta (2014 model) for a year now. Last week, the whole stereo system stopped when i tried calling from my phone (Dialing from the stereo and not from the phone directly). This hangs the sound (so the stereo works if i change between media, radio, phone, settings, etc, but no sound and the Phone function stays stuck on the call.
Now the main problem is that the stereo does not switch off (even if i keep the On/Off) button pressed. Switching off the car also does not switch off the stereo. The only way i managed to sort this out was to disconnect what i think is the earth cable on the battery.
This resets the system and also caused my dash to light up with loads of systems that failed, until i had to turn the steering to the left and right to re-calibrate the systems.
So. Is there a hard reset for the stereo in case this happens again? And is there a fix to the stereo to prevent this from happening please?
