Agreed, so many factors that effect fuel economy aren't taken into account. But a lot of threads that come up complaining about it are from brand new cars, i.e. the tyres should be inflated properly. But maybe they are over-inflated?No point complaining about MPG if you aren't even going to bother checking your tyre pressures![]()
WTH? I've never once complained about mpgNo point complaining about MPG if you aren't even going to bother checking your tyre pressures![]()
Whoops indeed :tut: Check the sidewalls for wrinkles, cracks or a different texture of the rubber around the middle. At 15psi you could easily have damaged the sidewalls. If your mileage isn't too high you should be alright...First time I checked my tyres since ive had it from new (9 months) and all my tyres were at 15 when they should have been 30.. Whoops :lol:
I hope that is a typo!!Went to the Garage 2day, My Pressure was 33 was on the fronts and 30 on the back. 1st time i've checked since i got it. I've always thought that my mpg and Handling were way off seems i found the culprit. So i've put it 28 on the front and 32 on the back. So lets c if there's a difference. Wot does every1 else put in the tyres?
this seems quite high, i found that when i increased the front wheels up to 2.5, it had more understeer when it was rainingI use 2.6 in the front and 2.3 in the back![]()
