Hi there! Maby someone can help me. I need the pressure for 17" wheels on a GTV, because mine comes originally on 16" but now it has this bigger rims, so I don't know if I just have to keep the pressure indicated in the original manual. I believe 2001 and on GTV's have stock 17" wheels son if there's any 3 phase user that could gimme this info i'll be glad!
The manual recommends 2.7 bar front (39 psi) and 2.5 bar rear (36 psi) although after reading this query somewhere else I run 38 and 36.
yep, Autodata lists 38PSI front, 36PSI rear.
Same pressure for the 16" and 17"
I use 39 front 33 rear
sounds strange, but when you consider that there's about 50% more weight on the front axle than the rear it makes more sense i think
