1 - 11 of 11 Posts
Hello, just wondering if there are any practical options or even ‘not too impractical’ as I want this quite badly. Probably end up on a 57 plate 147 Q2.
Thanks 🤓
It is possible. A shop called JTD performance in the Netherlands does have it, I happened to see it while browsing.
Here's the link. Don't ask me anything technical, since I'm a noob. I just remembered it does exist for the 147. :rotate:
Thanks 🤓
I would not waste a lot of money on expensive prebuilt exhaust solutions. A good exhaust shop can easily build you a 2 side exhaust for the 147. You just need a Y pipe after the cat. It is the easiest if you remove the muffler and run straight pipe after the cat, if it is legal in you country.
powerflow made my old 1.9 156 exhaust.
Why? Just how it looks? It won't work better, the exhaust isn't restrictive. Save money!Just fit a dummy tailpipe on the right. In fact, why not more? There's room for at least 10 :)
Hehe, a very fair point ! 🤓. Lots of disconnected thoughts as my answers .....
If there wasn’t a ‘cutout’ in the rear bumper, it would never have crossed my mind to lust after the conversion.
I suppose I enjoy having a ‘peasant spec’ car that projects no ego type statement like a Brera would. BUT there’s no point being cheap and doing without every simple pleasure. This is where the dummy tailpipe would fail to tick the box.
I have a fleet of three facelift 147 jtd’s that I expect will see me out as a driver although may not work out like that.
All the exhaust systems are original 12year old and the rear silencer box does look a bit naff. So one investment that could be transferred across to the favoured vehicle has a certain appeal.
My mate has several Jaguars of various eras from E type to current. All with twin smokers...
The 147s are in my opinion a bit of a shopping trolley especially in facelift version. Anything that gets away from that works for me. I’d go as far as to stick a prefacelift front end on the black Q2 if I find a breaker with clean panels. Not sure if the carbonio black is available on pre facelift ? (Only consider converting a black car as the rubber fenders are effectively invisible on a black car).
I expect the way to go is to get something made up in the way of a back box delete and indulge myself a little with the budget .
Yes, dummy pipes would be a chav crime against Alfa. The poor thing would think it's a Vauxhall with a 15" sub in the boot. Collapsing spring pans would give it 'stance'.
I think I must be odd in liking the 147 (and 156) even more with the FL front. Don't tell anyone, but I even prefer it to the GT.
1 - 11 of 11 Posts
