I keep hearing a "twanging" noise from under the front of my facelift 156 - sounds like under the engine toward the right hand suspension. it doesn't happen that often - just when i go over certain types of bumps. i used to hear it very occasionally but has been happening a lot more since the suspension took a good whack on a big pothole last week
the best way to describe it is it sounds as if a rubber bouncy ball has hit the underneath of the car:confused:
anyone come across this before or know what it might be?
Ages ago there was discussion about twanging springs that weren't quite seated properly. Maybe? Dunno.
yes - exactly the same thing happened on my 2001 156. Kwick fit wanted to sell me new shocks but my local garage sorted it out with a couple of cable ties. Apparently the engine guard that sits underneath the engine had a crack & one part of it had dropped. Every time I went over a speed bump I got exactly the same noise you described. Hope this helps
cheers julian, it certainly sounds like it could be that - particularly as the guard has had plenty of scrapes in it's time. gonna jack it up at the weekend and have a look
Mine does it sometimes, like when it's been left over a weekend and it's been damp. It does it once on a roundabout about 1/4 mile from where I live and is OK after that :confused:
Cheers,
