The turbo is a T 03 from a Fiat Coupe turbo 16v,the same as the one on a Q4 I presume?I am going to have it fitted on my homemade manifold,and then I have to turn the house in the middle of the compressor and the turbine(so the oil-output will be straight down).No problem on the compressor side,but the turbine side is teesing me.First the 6 bolts:-I had to use gas & oxygen on them before I could loosen them.Now they are all loose,but the turbine house is VERY stuck,and I won't use violence(unless it's the right way to do it wink ).
Anybody who knows what to do??
Discussion Starter · #2 ·
if you have all the bolts out then you will need to give it a smack they become very tight and rust themselves on be carefull to make sure it comes off straight you dont want to bend any blades.
Thanks jb,I will try that,but yesterday I went to next project who is making new excust from turbo to cat(or where the cat should be wink ).When this is done,I will follow you'r tip. :)
