I have considered it myself but not not gone beyond that. Presume you're looking at a low pressure conversion, in which case I suggest you look at a 1.9jtd. I know my 16v jtdm engine uses the same exhaust manifold gasket as the twin spark which means the stud pattern and exhaust ports will be the same.
So exhaust manifold, turbo, and downpipes - 1.9jtd 16v (possibly 8v too) should bolt straight on with little or no modification.
A lot of the control gubbins could be harvested from the jtd too.
Not sure what you'd do for a high pressure oil feed to the turbo but the return feed should be easy enough to sort.
The control system for the VNT turbo may be difficult though. Perhaps you could set it at a particular position and use other means to control boost pressure.
Intercooler and pipes to the inlet manifold's general location could also be taken from the jtd too. As for the manifold itself, I think you'd have to use an alloy from from a cf1 155 or 145, as I doubt the plastic one would survive long.
Engine managment will have to be bespoke and getting that to talk to the canbus system on a 147 will be troublesome. A 156 would be easier to sort.
If you want to go beyond that the search for;
Alfadublin
Here and on
forum.alfa156.net/forum
But what he did and achieved was daft imo.
