1 - 16 of 16 Posts
Since my car insurance doesn't cover while on track, While I'm on track the miles I'll cover will come off my limited mileage on my policy.
Having a think I came up with making a binnacle that I could fit in the pits within a few minutes and give me the details I'll need the most.
So thought tachometer is the most obvious, then Alternator and oil pressure light.
Since I have to indicate to allow faster cars past I thought indicator warning lights too.
I've jigsawed a piece of aluminium to the same shape as the original binnacle and cut out the tachometer also, with a few placed holes and a cut out at the bottom for the boost controller.
http://i246.photobucket.com/albums/gg92/explosive-alfa/00b43d08.jpg
Using LEDs for my warning lights I had to solder on a 1K resistor to prevent the LED burning out.
http://i246.photobucket.com/albums/gg92/explosive-alfa/cbf1983e.jpg
http://i246.photobucket.com/albums/gg92/explosive-alfa/c72a64dd.jpg
After soldering on the resistors I covered them with heatshrink.
http://i246.photobucket.com/albums/gg92/explosive-alfa/fe458539.jpg
Then I started installing all the components into the sheet of alu then soldering and finishing the wiring.
http://i246.photobucket.com/albums/gg92/explosive-alfa/a55fefd5.jpg
Finished article.
http://i246.photobucket.com/albums/gg92/explosive-alfa/25203d03.jpg
I installed extra connectors to the car's wiring behind the binnacle so I can simply plug and play, I couldn't take pics as it was too dark, but here's it installed and tested, seems to be working :D
http://i246.photobucket.com/albums/gg92/explosive-alfa/7939a066.jpg
http://i246.photobucket.com/albums/gg92/explosive-alfa/2180ad1d.jpg
Nice work mate looks really good :cool: cracking idea to change the clocks your quite useful with electrics!
Also, I think the boost controller looks better relocated to that position :thumbs:
I like what you've done, nice and simple, but wouldn't have disabling the speedo signal have been even simpler?
Unless it's a radio/cd player fuse........;)
Sorry for mentioning that mate, couldn't resist.......:thumbs:
Binnacle is a great idea, does the job for track time.......
1 - 16 of 16 Posts
