Funnily enough I got an email from the MSA today as part of the ongoing updates to the Blue Book regs.
One concerned towing Eyes and I noticed it stated that they should be capable of taking a force of 2 tonnes and, strangely, if bolted on should be bolted with at least one M10 Gr 8.8 Bolt.
Now 2 Tonnes (20KN) is a fair old force, almost double what which would be required to actually pick the Car up and dangle it off it's Towing Eye. Would you do that off a bumper fixing and stand underneath, I bloody wouldn't I can tell you that for nothing!. Oh and they want two of them on the front too.........
Here's the proposed new wording, the original wording is crossed out, but I couldn't format that on here, so its in Italics and should be disregarded.
Q19.1.3.
a) There must be substantial towing
eyes securely fixed to the main structure
of the vehicle, front and rear, within the
confines of the body to enable the
vehicle to be moved. Cars of periods A
to F and single seater racing cars are
exempt from this requirement subject to
a suitable towing point being clearly
identified. Towing eyes must have a
minimum internal diameter of 60mm.
Towing eyes/towing points should be
painted a contrasting bright colour
(dayglo red, orange or yellow, marked
with an arrow and the word “tow”.
b) The following configuration and
specifications are strongly
recommended:
Vehicles to be equipped with two front
and two rear towing eyes positioned
equally either side of the longitudinal
center line.
The towing eyes to be made of steel
wire rope of at least 6mm diameter steel
wire rope with a 6x19 wire core.
Each towing eye to have a breakingstrain
of at least 2 tons and allow the
passage of a cylinder with a diameter of
60mm, situated 25mm forward of the
adjacent bodywork - 100 mm above and
below this hole must retain clearance to
enable the recovery crews to attach
straps and shackles.
They must be clearly visible, marked
with an arrow and the word “tow” and
the wire painted in yellow, red or orange
to contrast with the vehicle colour
scheme.
The towing eye to be fixed to a structural
part of the chassis with a minimum of
M10 (Grade 8.8) fixings, the inner part
must be flexible in order for the towing
eye to be retracted inside the bodywork
profile.
Towing eyes should be situated 25mm
forward of the adjacent bodywork with
clearance of 100 mm above and below
to enable recovery crews to attach
A “pull-cord” to be attached to the towing
eye to enable the marshals to access it.
The end attached to the chassis may be
either ‘thimble’ or ‘open-loop’ style
