1 - 20 of 69 Posts
Has anyone managed to get the torque app on Iphone or android to work with their GT via bluetooth?
If so which protocol did you use?
156 won't work ... wrong interface type. Can only use a VAG-COM KKL interface cable with AlfaDiag or FiatEcuScan. Old interface spec.
147 and GT should be ok with ELM interfaces and FiatEcuScan, and VAG-COM KKL interface cable with AlfaDiag or FiatEcuScan but no idea about phone apps.
Jake: tried a search?
I've done some searching not really found much help.
I noticed in the app there is an Alfa/fiat protocol being developed still so might be a no go. Although if I select auomatically select protocol it will try to connect and you can see the dash lights and speedo do things for about a second.
Works OK on mine. I don't believe other than telling it to use bluetooth I chose any protocol. Are you sure the ELM device you have is compatible?
Yours in the 20v, so it's quite a late car and uses a canbus setup.
Works on my 2005 JTS too. Definitely not CANBUS, but I suspect it was standards compliance introduced later.
Correct, the bluetooth ODBII adaptors are ELM327 not KKL, so it won't work with the 156. Although I have no reason why it doesn't work as the ELM should work on both systems.
As far as I know, which is not far, ELM327 is the physical interface and you must then pick a logical protocol to talk over it with - KKL, which is what Torque uses.
Discussion Starter #15
Right I've got it working..
My Elm327 needed some modding as instructed from the FES forum...
Simply removed a 120 ohm resistor off the board and works a treat now. :)
1 - 20 of 69 Posts
