I have my v6 front end stripped and replacing wheel bearings,driveshaft boots,interrmediate shaft bearing and springs/struts, but I note that the RH top mount bearing is notchy. all rubbers and mounting plates are fine.Ideally I would put 2 new mounts on if I could find pair but as left hand unavailable I am wondering if this bearing :
Friction Bearing, suspension strut support mounting 866000 Front Axle from RUVILLE - ALFA ROMEO
listed for GTV, could be fitted if the 2 plates are separated.
Has anyone managed to separate top mount plates?
