A
alip
·Guest
mine is ALFA 155 TS 16V 1.8. the upper engine mounting (a rubber bush fitted on the cast aluminium bracket that tie to the body beside the cambelt cover), was broken. Thoroughly checked and found that the rubber was totally wared and gone! i try to locate the new rubber bush for replacement but none of the parts shop stocked that damn bush! As a result, my engine vibrates constantly...Is there any ideas or whatever that can solve the problem?
PLEASE, I NEED HELP FROM YOU ALL.
