Today's little job
2919 Views 12 Replies 8 Participants Last post by  Durty dog
Replace the lower wishbone balljoint boots.
Nicked both of them doing the bearings a month or two back....the MOT is booked for Friday.
Wish me luck.
Pub
1 - 13 of 13 Posts
Remember NO beer when doing maintenance :)
todays little job for me.... buy scrappy upper arm bracket and fit as two bolts for bracket through tower stripped for no apparent reason :(
oh and grab a pass tie rod thing (as pass tre and tie rod will not come apart) to allow me to fit new tre. wouldn't usually but parts place sent me wrong item and these will be a stop gap till I can find trw replacements at bargain prices :)
already had drivers tie rod and tre changed, upper and lower arms, drop links so just finishing off really :)
For me, just hunted down and killed the dyslexic duck that had been living in my drivers door. Thankfully a quick and simple hunt to replace the door strap. No more Clack Clack Clack when I open and close the door.
Wish me luck.
Pub
Where did you get the boot from?
I could do with one
No work on the car for me, am presently sat in a and e to find out what the loud pop and excruciating pain that followed is in my ribs!!
I could do with one
Ball Joint Boots
Well, didn't start too well. Had a bit of a sleep, working nights this week, and...... my balljoint splitter, erm split at the second whack of the hammer.
Just sent my neighbour out for a replacement.
Good job the weather's nice and England are doing well in the Ashes.
Pub
2
All done, satifying job
Auto part Vehicle brake Drive shaft Wheel Brake
Auto part Suspension Suspension part
Tricky getting the top securing ring on. Bottom is easy, just put it onto the boot first then slide it on to the balljoint.
Top one was another matter, finally had a brainwave, I had an old piece of plastic waste pipe just about the right size to slide the clip over, place it over the boot then gently ease it off the pipe and onto the boot.
Time for a bath and listen to TMS, should be declaring soon.
Pub
See less See more
My little job of the day was to replace the belts and pulleys, I also replaced the cams with new B&C fast road cams and a new variator. I was advised due to the mileage of the car not to bother with the water pump. I hope I made the correct decision. Anyway, now up and running, sounds better, I think the old variator was rattling a little.
My little job today - new front and rear Alfa badges on the GT.
Bring on the bling!:cool:
Man the old ones were faded.
Hi
Just seen this thread - can you just replace the ball joints without replacing the whole arm?
I always thought they came as one with bushes etc...
I need to replace my top ball joints on the upper arms (Alfa 156) are these in the same way?
View attachment 182233 View attachment 182241
Pub
How much of the suspesntion needs taking apart to fit these boots??
not looking forward to trying to get the locating ring on the bottom
For me its going to be droplink replacement
1 - 13 of 13 Posts
