1 - 20 of 42 Posts
Hi Folks
I am considering investing in a pressure washer instead of paying our local car washers to clean my car. Does anyone still wash their own car and if not, can you recommend a decent pressure washer for doing the job? I don't want to spend over £300 and I am quite tempted by the following clip which shows a guy cleaning his car without even touching it:-
May well invest in a leaf blower to dry the car. Also, can anyone recommend any decent cleaning products, shampoo, etc...
Any finally, what are people typically spending on getting their new car detailed? I have been quoted around £700 which includes a glass coat - whatever that is.
Garage up the road has pressure washers and snowfoam lances.
I spend 4-5 Euros a go. 1 Euro to foam up. 2 Euros each to jetwash
with warm water and rinse with softened water.
:thumbs:
There's no way you can get all the crud off without touching the car.
I got a glass coat for mine, depending which one it's a minimum of £700 for a good one, mine was more, it depends on the length of the guarantee with my detailer as he has different products. I clean it myself, which I did earlier today. If you get a cheap car wash you will end up with swirls in your paint which rather negates spending £700 on a coating.
You don't need to spend £300 on a pressure washer just for a car. A pressure washer jet is often too high pressure for a car, it can damage the paint. It's for rinsing soap off and loosening surface dirt ideally with foam. If you use a normal jet on full blast you can spray dirt into the paint.
You may be better getting a cheaper one, but make sure you get the right accessories.
I use a Nilfisk C110 4-5 with extras such as an extension hose, an auto head to reduce the pressure making it easier to Rinse, an underchassis nozzle and a good (not nilfisk) container and nozzle for foaming it. The build quality of Nilfisk seems to be higher than the Karcher I had.
For my staple bits of kit I use Gtechnik mitts, and two buckets with grit guards with Gary Deans Perfect soap. I also use the soap to foam it as well. I use two really thick microfiber cloths to dry it, you use one to just lay it on the car to soak up most of it and another for the final buff. My preference for the first of the towels is a professor plush towel from fleck philosophy and a woolly mammoth from chemical brothers to finish it off. I also have Bilt Hambler wheel cleaner with some wheel brushes.
The microfiber cloths are cleaned with a microfiber cleaning solution and stored in an air tight container.
My general clean is:
1) Clean the wheels
2) Foam it
3) Rinse the foam off
4) Clean it with the 2 bucket method
5) Rinse it
6) Dry it
I'm still a novice at it and am looking at leather cleaners, tyre dressing and glass cleaners. There are forums on Detailing and I tend to see what those folk are using and buy products with good reviews.
1) Clean the wheels
2) Foam it
5) Rinse it
6) Dry it
^This. You won't go far wrong doing the above. You can mitigate the swirling by not rubbing microfibres or mitts in circular motions - do straight up/down or left/right motions. Also wash dirt off from the top of the car downwards.
Peter
Buy some Swisswax cleaner and some of their polish and enjoy the bonding experience. The hundreds of pounds is a mixture of labour and margin. And you don't know if it's been carried out well, at dealers anyway. Detailers are obviously better but you'll still miss out on the tactile experience of applying the very expensive wax.
I'm with Stuart. I also use a Nilfisk - they have all brass internals, unlike Karchers etc, which means that they last much longer. Kranzle are probably the best, but much more than the Nilfisk.
I too have a ceramic coating, then 2 layers of Exo 3. This means that I have a super hard coating to reduce marring and swirls that you get from cleaning, plus the super hydrophobic results from the Exo. Other products from the likes of Gyeon, Carpro, SiRamik etc are probably just as good and you'll pay around £800 or so for a single stage polish and the coatings, inside and out. It is key to get the wheels done when off the vehicle, so the barrels can be treated as well.
My regime is then like Stuart's, although I use a 3 bucket method - an extra bucket for the wheels.
I'll post my product list in a while, but I can promise you'll keep your car looking way better for longer if you do it yourself than taking it to a hand car wash.
Ok, NBBMW - you asked! My wash routine is admittedly a bit anal, but is as follows:
1. Spray wheels with Iron X fall out remover. Use small brush to work into tight areas. Allow to dwell for a few minutes then jet wash off, included wheel arches. If your wheels are treated, they'll now be 90% clean
2. Spay wheels with strong dilute solution of Dooka Wheel Shampoo. This is a PH neutral wheel maintenance shampoo. Allow to dwell, then jet wash off. The wheels are probably now clean. Never use acid.
3. Using Dooka Wheel Shampoo in a 5litre bucket and a lambswool wheel pad, clean inside and outside of spokes and the wheel calipers. Jet wash off. Your wheels will now be ultra clean
4. Apply snow foam. I use Lovely Bubbly after trying loads of other products, with a specialist snow foam bottle with a fitting to suit my Nilfisk. While it is dwelling for 5 mins, I fill my other 2 5litre buckets, which both have grit guards in the bottom. Jet wash off, but ensure you jet wash at 45 degrees to the paint, not 90 degrees.
5. I use Carpro Reset shampoo. 40ml in 5 litres is about right. I use a good wash pad (Dooka) and the object is to swish this over the paint with as little pressure as possible. Again, with the coatings and the shampoo, the wash pad should feel really slick on the surface. Use one bucket for the shampoo and the other to rinse your pad. Jet wash off.
6. I live in a hard water area, so I then rinse with softened water using a Race Glaze cylinder through my jet washer with the pressure attachment removed, so that I can sheet off the water. This leaves the car almost dry.
7. I then dry using Monster drying towels for the paintwork (using zero downward pressure) and small yellow Dodo Juice drying towels for the wheels.
8. I use the damp drying towels for all the door, boot and bonnet shuts etc.
9. Every 3rd wash or so, I treat the tyres with Gyeon Tyre Dressing. This lasts really well.
10. If I have lots of bug splatter, I use Gtechniq Bug Remover and allow to dwell as I'm doing my wheels.
11. When needed, I clean the glass with Dodo Juice Clearly Menthol.
12. Non abrasive Chrome cleaner on the exhaust tips
This takes me about 50 minutes and I've grown to really enjoy it, particularly on a car as sexy as the Giulia. I don't even let the garage valet it when it goes for a service.
Others will use other equally good products, but I've found products such as Dooka and Lovely Bubbly after many years of trying other products. The ceramic coatings, including the hydrophobic work best when they are decontaminated. For eg, I don't have to use my windscreen wipers in the rain over 50 mph and the car stays cleaner for longer and is easier to clean when it does get dirty. Ultimately, what you are trying to do is avoid marring, hologramming and swirl marks in your paint, particularly if you have a dark colour.
There is a whole world of reading and research if you want to get into wax vs coatings!
Bet you wished you never asked!
Thanks for the extensive notes mate. I have seen a number of YouTube clips showing this hands free method. In-fact the car detailer i am looking to use suggested this could well be possible but very much depends how dirty the car actually gets before being cleaned. I certainly do not want to wax the car especially if i can pay someone to do the job far better then me...
I just applied some sonax polymer netshield. It's much easier and cleaner to work with than wax. The shine is better with carnuba wax, but the netshield should last for much longer. It also makes the plastic and rubber details look like new. Still remains to see how it holds up, especially on salty winter roads.
If you look after it, the ceramic coating will do several years. You can repair micro scratches in ceramic with products such as Car Pro Essence Plus. Hydrophobic coatings such as Exo3 should do 18 months to 2 years. The best waxes will do 6 months at best.
You can often get a 'warmer' shine from carnuba wax, but if you pick your coatings carefully, you can almost match the gloss level you'd get from good carnuba wax.
Pick an experienced detailer that uses several of the ceramic coating manufacturers and let him choose which coating to use for the best results.
The Swisswax was beading pretty well after 7 months but I redid it anyway. A pot of the stuff costs the same as an hours labour at main dealer, so it's a bargain.
I had Autoglym Lifeshine on my new Giulia, some kind of ceramic coating apparently, it was sold to me as "the best available", and comes with a lifetime guarantee. Since I've never kept a car longer than three years, that should do for me. I'd only had the car a couple of days when I drove to the yacht club to meet a friend for lunch. It was a nice day so we sat outside. Shortly after we sat down, a massive Sunseeker motor yacht drove onto the boat lift, and once out of the water, it's props and underneath were blasted with high pressure sea water to remove weed. The overspray went every everything in the car park, including all over my lovely new Alfa, leaving a trendy matt coating. I mentioned it to my salesman at Westover, and he assured me that just water from my garden hose would restore the pristine finish, no rubbing required. It rained all day today, so I'll do it tomorrow, and we shall see, so watch this space...
Banned
Metro Blaster is designed for the job, warm air and filtered to prevent motor particles or grease being sprayed on the car
https://www.metrovacworld.com/catalog/Auto
https://www.carcareproducts.com.au/product/metrovac/blaster_sidekick
glass coat? no, ceramic coat is way better, its a paint protection with very minimal scratch protection but it leaves your car virtually waterproof and much easier to clean
i used Opticoat and it is considered the market leader at this time ... research it and see if you want it, but it needs to be maintained in so far as you have to take it back to the detailers every year to have it enhanced and prolonged
Opti-Coat Pro Coatings | Opti-Coat LLC
stay away from glass (silicone based), its ceramic all the way these days
the Opticoat Pro+ cost me the equivalent 395 of your British Pounds, but typically it costs about 500-550 squids (i got a good deal because he was keen to do the Giulia)
Banned
many say the ceramic coatings advantages and protections can be duplicated with good old fashioned regular wash and wax ... the difference is you have to keep waxing, this is done once and forget ( but you have to keep washing)
personally even though i used the Opticoat, i think you can get your car shinier for longer after a good regular wax, but this product is for people who might miss a winter or a few months or so
I also got the opticoat, $895 Aussie and it came up beautiful, well worth the investment
Whats all this 2 bucket stuff? If youve got a hose to run a pressure washer why not just hose the car off with a spray attachment?????
I use a bucket of water with a decent shampoo in and one of these:
Trade Quality Telescopic Wash Brush
Washing from the roof down and rinsing as I go, a mit on the areas arounf the mirrors etc and then dry off with a micro fibre cloth.
Dont need to make it complicated and you wouldnt if you had three cars to wash like I do!
  • Like
Reactions: bucketbot
1 - 20 of 42 Posts
