Hi All.
Driving a 1.8 TS (111000 km).
The battery icon starts/stays (slightely) lighted after I turn the engine on, then fades slowly off in less than a minute.
Measuring the battery voltage, engine off: 12.40 V. When the engine is on: no more than 12.80 V!
I guess it should be around 14 Volts.
I changed the battery 6 months ago!
On the alternator side, the Vcc output connector gets quite warm. Normal?
If it's the alternator:
Does the alternator can be fixed or should it be completely replaced?
It's behind the engine. Can I change that, or open it to check the electronics, diodes inside? Or something not worthy to do, too dificult (distribution belt stuff tricky), and better go to a car (electrics) specialist/garage?
Could it be another alectric part damaged between the alternator and the battery?
Thanks.
Cheers,
GIX
Sounds like your Alternator you can get them repaired but you tend to find they dont last long before they fail again
Would reccommend you get a new one might cost a bit more but worth it in the long run
HI Jimybob, is the voltage regulator into the alternator or in a more simple place ?
cheers
Jorge
its built into the back.but you can get it replaced i think its even on the parts c.d as a part on its own..you will need to find the alternator then open up the sub section to find it on there..........
yes it is there i just looked.though looking at the price of them(£50.!!) it will be cheaper to get it re-built by a specialist...
