1 - 15 of 15 Posts
my brother in laws 01 2.4jtd was by the previous owner mean,t to have changed the timing
belt, but now the car has a noise from timing belt tensioner . sounds like a bearing.
i told him to change the timing belt with a new kit, but is woried about driving it any more
in case the bearing fails and wrecks the timing belt. would it be still safe to drive for a few days
untill the kit comes.
No, it won't be safe. Are you sure it's not the auxiliary belt tensioner or guide, very close and known for noise. I've just replaced my aux idler.
I was convinced what turned out to be my aux belt tensioner was the air con compressor clutch. It made a rattling noise when the air con was switched on, and you could see the belt snatching and moving slightly side to side. I doubted the air con was the cause and so it turned out. The tensioner is £100 or so on the 2.4!
On mine the adjustable idler was whirring, it was about £30 from memory. Aux belt separated from the cam belt only by the plastic cover and can foul the cam belt if it fails making it jump. I'm sure cam idlers and tensioners can fail but when I changed mine at 165,000 miles they seemed fine, they must be fairly robust. Previous owner put a belt only on at 95,000.
You should take the aux belt off and run the engine, if the noise is still there then it is the timing belt idlers or water pump and you shouldnt drive it untill it is fixed.
ok it will be fitted by a reliable mechanic and i will let you know the out come later in the week.
i think the timing belt idlers and water pump should be changed, i will let him know what was said here on the forum.thanks guys.
Waterpump hasn't been an issue on the 10v JTD, but you can change it if you want.
for about £40 i thought the water pumps on the jtd,s would
need to be changed just in case when you are changing the timing belt any way:)
1 - 15 of 15 Posts
