hi guys not long had my gta its only coverd 34k and i a can here a noise i am sure its the thrust bearing as when i dip the clutch the noise goes are they a little noisy as standard? As if not will get it sorted on warrenty thanks for any help
Three bearings that come to mind when the clutch is dipped, clutch release bearing, crankshaft thrusts, and sometimes, only sometimes, the gearbox first motion shaft bearing can change it's note. Most probably your clutch thrust bearing though? It'll get noisier over time if it is a suspect?:):
PS. Off load, can be that first motion gearbox shaft bearing!! Sorry, misinterpreted your post, as I'm still snoozy!!:eek: :(:
K
It sounds like the release bearing, as soon as it has any wear on it it will be noisey with the cluch up. mine was and just lived with it until i got the cluch changed plus Q2;).
