So I have found the ECU reset instructions, but I can not seem to find the instructions for a GT throttle reset. I have searched and all I find is reference to it but no instructions.
Anyone know where it is as i'm sure it is on here but my search skills are not up to scratch. Cheers
If you've found the ECU reset, I bet the second half of the instructions relate to the throttle...
yup yup I just worked that out. Throttle reset is part of ecu reset.
Admin can delete thread if they like.
Yep.
If you just want to do the throttle reset alone , you dont disconnect the battery n all that , just start from the 90 sec on , 90 sec off n so on.
But I guess you've figured that already :D
the throttle reset is the bit after leaving battery disconected.......re connect battery, turn key to "MAR" leave for 90 seconds.........turn off, leave for 90 seconds.......then rest is ecu reset
Gary
