depends on how.... If it get's a cool air feed, no problem. Otherwise don't do itGuys, I want to install a K&N Cone filter on my 156 2.5 v6.. is it advisable to do so?
Sent from my SM-G925F using Tapatalk
for instance....So u suggest I box it?
Not if he gets one that doesnt need oilingNoisy and no performance gain. Also the oil for the filter can damage the MAF sensor.
Sweet bru... it looks good as well... think I will do the sameI have a GT V6, and on my car under instruction from a local Tuner Garage who has knowledge poking out of every orifice, he said to put a Medium size Ram Air (Cone) filter on, so I came from the throttle Body straight forward then a 90 Bend down too Half way down the Radiator, supported it, and then to put the 2 Oil Breather pipes into a Catch tank (As the Oil Mist that may get put back through the intake can Dumb down the Octane level of the Fuel (how true that is a don't know, ha, But what do I know)
And for me its worked a Treat, I only have a small amount of Induction noise low down if I plant it, but I haven't had any of the Bogged down feeling you usually get. To be honest id rate it above my BMC I had on, also the whole lot was the same price as a BMC and the little nits needed.
Not advisable. The v6 has a wonderful induction raw that doesn't require tampering with.Guys, I want to install a K&N Cone filter on my 156 2.5 v6.. is it advisable to do so?
If so, which would you consider ?Not advisable. The v6 has a wonderful induction raw that doesn't require tampering with.
On a jtdm this would be pointless from a performance aspect as the engines run lean on fuel so more air would not help. However, I do agree the intake is quite low and the current filter is annoyingly difficult to change. If the noise was bearable I'd consider modification of a jtdm.
