This thread is inspired by a similar one in the Jaguar X-Type forum that I used to contribute to a lot.
Essentially - what features have you discovered about your GT that aren't documented in the handbook (or at least you never expected to find in there...). Some examples for the Jag X-type was that the headlamp washers only operate every 6th time the windscreen washers are sprayed (and not at all if the low windscreen washer water light is on), and that if the fog lights are on they will extinguish if you turn on the main beam lights.
First off on the GT - there's an alarm beep that sounds if you attempt to pull away with the handbrake on!
