1 - 9 of 9 Posts
Yep, been tinkering with the V6 again :rolleyes:
The car would take ages to warm up, even zooming down the motorway at 10mph (my speedo still isn't fixed).
When it eventually reached 90ºC or above (the fan kicks in just below 100ºC :eek: ), it wouldn't cool down, eventually after about 15 miles at constant speed on the motorway, the temp would drop to about 70ºC.
I thought the stat is obviously stuck open when cold, but not opening enough when hot.
Took the stat off when cold and yes, it wasn't fully closed. Dropped it into a pot of boiling water and it didn't open any further. I think the car sitting for so long had allowed crud to build up.
Anyway, some release spray and then blasting with a blow torch for about 5 mins, the rod started to move and open the stat, could see a line of crud on the rod so out came mr emery board.
Once rubbed, I dropped the stat into cold water and it shut properly.
Stuck it in hot water again and it opened slowly :D
Put it back on, car warmed to 80ºC at idle in about 5-6 mins, eventually it reached 90ºC, then the fan kicked in and the temp dropped nicely. The heater works properly aswell now.
Need to take the car on a drive to check it properly, but I think I may have saved myself £25 !!!!
Great sence of achievment when it all go's well, and checking out your post's you need it..........Well done mate......... :) :) :)
So, you identified the problem, removed the part in one piece, fixed it and put it back on the car succesfully and at no cost, and it all works fine.
That's not tinkering....
Well done though :D
Discussion Starter · #7 ·
Well the car had it's first test of it's revived stat this morning.
Got onto the motorway, booted it and the car quickly got to 90ºC. I thought it was maybe too quick, but I can't remember how quickly a car with a good stat heats up. Was worried I was gonna have to stop, let the engine cool down and remove the stat altogether :eek: .
Anyway, it didn't get any higher than about 98ºC and that was when I was sat in traffic.
On the whole, the cars temp fluctuated from about 89º to 92º, so if this continues, I'll be happy..............
1 - 9 of 9 Posts
