1 - 12 of 12 Posts
Hi ,
As I've understood from forum that many of members changed their thermostat on 146 1.6 boxer (from 1996).
Please can you tell me how the whole process have to be done?
What points I should know before start working on?
What tools are needed (or just that's so simple as it looks like) ?
Where did you get water out from the system (if you did) and how much of water (cooling) I have to drain?
Air bleeding after, where from ?
Additional info, that you have.. ?
Thank you in advance
Yefim.
P.s. mabe you have pictured this- will be appriciated.
..thanks again
If the 1.6 is a twinspark engine then:
Heres where it is:
http://homepage.ntlworld.com/jacksalfas/Forums/155 2.0 TS Thermostat.jpg
Changing it is very easy, part costs about £40+VAT
You need to disconnect all the hoses, buy some jubilee clips as if it has not been done beofore the factory clips might break when you take them off, some will be stuck hard. When this is done there are two 13mm (might be 10mm cant remember) bolts holding to thermostat on.
Just let the water drain out when you take the old one off.
Once you have removed these give it a tap and it will come off, check both contact faces are clean and reverse what you just did, refill with water/antifreeze.
Turn the cabin temp to max, leave the filler cap off while it gets up to temp, this should get most of the air out, also give the top hose a squeeze for good measur.e
Good luck :D
copied from:
http://www.alfaowner.com/Forum/alfa-155-tech-room/33359-changing-the-thermostat.html?highlight=changing+thermostat
Hi and welcome :p
1 - 12 of 12 Posts
