3101 - 3120 of 3158 Posts
Discussion Starter #3,102
The missus has plans for lighting.
I'm aiming for delicate, moody and restrained. Next doors looks like the aftermath of a trolley dash at B&M.
Discussion Starter #3,104
I've now got 2 L shaped beds built
they take some filling mind, though the dog has tried to help twice
soon I will be laying aggregate and wacking off a bit
then laying some self-binding gravel
did I mention a log store?
Discussion Starter #3,105
Bought an electric fire to replace gas. It is to be inset into the normal builders hole.
It kicks out a mighty 2kw, just like the 9.99 hyundai heaters you can buy from anywhere.
It costs just shy of 600 bar cos it is cast iron and looks like a stove. It is a pure vanity waste of cash.
Yesterday i afternoon I offered it up to the granite thingy, marked holes and drilled. Online advice pointed to diamon cut drills, but two ordinary masonry bits worked a treat - after hours of sustained tunneling and occasionally spitting on the bits (Fred's been out with her).
I offered the hugely heavy stove back to the wall, and the holes are substantially in the wrong place. I can't understand why, but tensions were high last night.
What do next? Plan is, drill hole biggerer, and then pack it with matchsticks and no more nails, and whack a big rawlplug into hole, and smll rawplug into big rawlplug.
Administrator
You should have stuck to the outside stuff. At least then, when you got things thrown at you in temper, it didn't make a mess on the carpet.
Discussion Starter #3,107
The fire is secured to the wall, in front of a gaping builders entrance. Sit down for how I did it.
My tactical options for rectifying a mis-drilled hole in granite were as follows:
1 - replace entire edifice and drill
2 - declare the task impossible to mortal man, give up and sell fire on ebay at colossal loss
I mulled these over for some time, weighing the pros and cons carefully. I came up with the following solution:
drill MUCH BIGGER holes, much larger than any I have rawlplugs for, and drill them at a slanty angle - fracking style
This created an ovoid hole. I retired to the garage and rummaged - inexplicably I unearthed 2 mahoosive rawlplugs. No recollection or evidence of purchasing these. I like to think of this as some kind of benign intervention. I jammed them into position. On the RHS I also jammed in a small wallplug and 2 matchsticks.
With these in place, I offered up the colossal and weighty cast iron monstrosity - and screwed it in. Securely. With two tiny, thin, spindly screws. It is holding.
Previously I had chopped off the plug, making the warranty void, no doubt - so I could thread the cable under the hearth (and it's wooden sub-structure) and towards a socket. I had drilled small holes through the sub-structure which contained 3 cross members. The 1st cross member was easily negotiated - but the other two were unsighted, underneath a wooden plinth that could not be moved.
Into the ultimate exit hole I shoved a metal bbq skewer until it went through the bulkhead holes, then I cable tied the power cable to the skewer and proceeded to do what Boris Johnson seemingly finds difficult.
I wired the plug and now we have a working, secure, beautiful looking fake (real) cast iron electric stove which looks nice, feels quality, and kicks out **** all heat like a ten quid caravan spesh.
Administrator
Just thank goodness its not like reading a courtesan's diary.
Administrator
What a returning post that is! Welcome back Zulu.
