1 - 17 of 17 Posts
on the side of the road today.
Yes 05 plate GT 19k and the clutch goes after pulling out of a junction.:mad: Stuck in first gear so can`t move it.:rant: Contact Alfa Connect and they sent out the AA after about 75mins:rolleyes: He says straight away that he thinks he knows what the problem is, a spring pin that connects the clutch pedal to the master cylinder, but hes never seen one go yet!
So has a look and yes he right, and goes to his van and gets a pot rivoit and bends it to make a temporary repair.Job done good as new.:) But why???........why such a stuiped thing makes and alfa look so unreliable!!:rant: I could see peoples faces saying serves you right you shouldn`t have brought an Alfa,the part cost pence.
That s my rant over, booking it in tomozz at Meridens, just so you now know if you get the same problem the clutch pedal goes to the floor.
One nice thing is the AA man comes up o me at first an says "whats up with this beasty"just made me think it is still worth it!:inlove:
A while ago!
Ninja edit: I think I read about this way before Oct 2006.
The AA (via google cache) gives:
New search
Recall: No. 1 of 2
Recall Ref: R2006/166
Exact Model: GT and 147
Description: Clutch may fail
VIN: GT ZAR93700005156078 to ZAR93700005298888, 147 ZAR93700003185703 to ZAR93700003777404, GT ZAR93700003254498 to
Build Date: ZAR93700003334641, 147 ZAR93700005155403 to ZAR93700005260743
Numbers: 5355
Defect: On a number of RHD Alfa Romeo 147 and GT models, there is a possibility that the clip which secures the connecting pin between the clutch cylinder and the clutch pedal may become detached, resulting in loss of clutch operation.
Action: Recalled vehicles will be fitted with a redesigned retaining clip.
Launch Date: 17 October 2006
Recall: No. 2 of 2
Recall Ref: R/2006/128
Description: Braking efficiency may reduce
VIN: GT ZAR93700003144007 to ZAR93700003321295, 147 ZAR93700003228724 to ZAR93700003328468, 147 ZAR93700005144149 to ZAR93700005216111, GT ZAR93700005081439 to ZAR93700005210113
Build Date:
Numbers: 3950
Defect: The Vehicle Dynamic Control (VDC) system does not operate properly when the space saver spare wheel is fitted. This could lead to the VDC warning lamp operating and may lead to reduced braking efficiency if the brakes are vigorously applied.
Action: Recall the vehicles that are likely to be affected to fit a new VDC electronic control unit that has upgraded software installed.
Launch Date: 19 September 2006
Luck was on your side, very similar trhing happened to me after only 7 miles in my brand new GT, also stuck in 1st gear. Unfortunately RAC weren't able to fix mine, had to go to the dealer, result, burnt out clutch !!!, (down to the riverts, knackered flywheel also just for good measure), after being blamed for the problem, (technician reported driver error!), ALFA UK agreed to fix it. Am now enjoying my GT ownership !!
D
Ah who cares, she looks stunning!!! :inlove:
I'm waiting it out until they costs about £2000 :lol:
ha...ha...you lot.....
Thanx Alfa Mad for digging up that information much apreciated.
Nkbutler....sounds like I got off lightly then...pheu...
how can i find out if my 10,000miler 55 plate GT went in for the recall?? i bought her from an alfa dealership 3 months ago so will they have records?? :confused:
1 - 17 of 17 Posts
