Apologies for posting what must be the 250th post about this, (I have gone though most of the posts i promises) but i have the dreaded notchy/stiff clutch syndrome, where it's fine one minute, then randomly it gets stiff half way through the travel, and also worryingly doesn't feel like i get the full length of travel sometimes.
Anyway reason for reposting this issue is because the few pictures I have found dont seem to accurately (or in simple terms) indicate what i'm actually looking at! :smash:
Here is my photo:
https://scontent-lhr3-1.xx.fbcdn.net/hphotos-xpa1/t31.0-8/s960x960/12973335_10154047015175586_6289004914888028175_o.jpg
Can someone point out exactly what it is im meant to be 'fixing'?
Now I want to use the fix'es suggested here:
1)http://www.alfaowner.com/Forum/alfa-147-156-andamp-gt/806170-gt-clutch-pedal-squeak-creak-physical-cure.html
2) http://www.alfaowner.com/Forum/alfa-147-156-andamp-gt/308272-clutch-pedal-creak-squeek-permanent-fix.html
Where he mentions "turning the master cylinder piston round 180 degrees" is he on about the white spring bit with the grease all over it? If so, how do i get to it/remove the clip etc?
And where should this extra washer go etc etc??
Also is this fix still the best/most up to date one?
N.b. I had a new clutch fitted a few months ago.
Here is my photo:
