I'm trying to figure out where the problem is with my wife's Alfa's blinkers. Started as a once-in-a-while not working problem, now if I flip the turn signal stalk up and down rapidly, they'll work for a bit, and then stop again.
I'd like to test things without having to reconnect the airbag each time, but if I reconnect power with the airbag disconnected, is that going to give me some big headaches?
The blinker module I tested on the bench with just a 55W headlight bulb connected up, and it blinked, but I am wondering whether that was a sufficient test. Also wondering if the hazard flasher switch could be a part of the problem? There must be some electronics there, as I don't feel it "click" when I push it in, so obviously ins't mechanical.
Got to get this sorted out quick, as the technical control of the car is coming up next week, and while in Slovakia 20€ left in the ashtray can do wonders in whether the tester decides some problems are major or minor, lack of functionality of blinkers would fail regardless (and, you know, safety on the road does matter to us as well :-D )
