Hi Fletch
I'm off work this week to finish arrangements for the Peak Alfa Day but seem to be spending most of the time on here wink
If its a '96 then it will have the Code. Chris has been helping me out with this as its a bit confusing. Pre-code cars you have to use a test lamp but won't go into that here.
For yours, put the ingition on "marcia" or the first position and then pump the accelerator five times in less than five seconds. The injector light will then start flashing the fault code. Its worth letting it go through it a few times just to be sure.
The code should be something like:
1 2 2 4 which is the lambda sensor.
Let me know what it comes up with and I'll check the codes for ya wink
Right, I'm off for a drive now
wrinx
