hello guys,
what might be wrong with my gtv tb v6? while driving either fast or slow.. the engine temp keeps fluctuating between 90 and 100 degrees? is this a water pump problem? there was no known problem like this not until i changed one of the busted engine water hoses.. before the hose change it was always steady at 90 degrees..
Hi
I think the temp will fluctuate a bit as the thermostst opens and then closes and the fans kick in. 10 deg does not seems reasonable to me. Can you hear the fans coming on and off at the same time?
It is also possible that you are noticing it now after changing the hose and being on temp alert, and in fact it had always done it.
Berni
