hi all just had the car couple months, its a diesel. I am aware that in this cold weather that it takes longer for the gauge to get to its norm of 90 .But last couple days its been fulctuating between 70-90 .I travel down A19 to work it reaches 90 stays there. Then when I pull of , slow down it drops to 70 or so .Then it goes back up to 90 I know it could be cold weather thats causing it just concerned that it may be something else any comments would be gratefully recieved cheers .
Mine does the same, also loses a little bit of coolant. It is worse for fluctuating when the coolant is full to the max line. Once it has dropped to the level it seems to stick at the temp sits between 85-90 indicated.
mine also changes with speed in the winter ...probably between 70-90 same as yours.
wouldn't be too concerned.
EDIT:
actually just been out in it now ....hovers between 85 and 90 ....never gets down to 70 after its warmed up!
