Hello,
does anybody here knows how to adjust the waste gate on the TD 2.5?
Are there any documentations available on adjusting the VM Diesel?
I have the problem that the output of the engine drops on WOT. Any solution on that?
TIA
amir
errr what is 'WOT' ..have you looked to see if the waste gate is seized in the open position..??
Wide Open Throttle..?????
make sure none of the pressure pipes are loose or leaking.
Yep, really meant Wide Open Throttle.
All pipes are as new, but where can I find the waste gate? Isn't it internal? And the silver rod on top of the turbo activates it?
As far as I know this rod can be adjusted when the turbo loses power.
the waste gate valve is on the end of that silver rod...i wouldnt adjust it because there must be something else making it loose power.
