Hi to all,
(I need to access to the wiring to be able to unplug and then push out enough of it to investigate a broken earth wire in the left hand rubber boot. I'm fairly certain this is the fault as left side tailgate lighting cluster is all dead, and then was intermittent when wiggling the rubber boot for a few minutes and now it’s all dead. Great.)
Please could someone explain exactly how to remove the tailgate interior trim? With a photo if you have one. I’d quite like to do this without breaking the studs or clips that I'm assuming are involved.
Many thanks if you help.
- Jon
- Jon
