1 - 2 of 2 Posts
Hi all
Decided I want a TI ride height rather than anything lower so I am planning to get some TA Technix springs. They come in quite a few flavours, but the ride height I want (25/20mm) drop is only listed for the 1.8 MPI, and the 2.0 JDTM isn't mentioned at all, even though I think the front/rear axle weight is the same as the 1.8 MPI. I would have thought that pretty much all springs are interchangable between all Alfa 939 derivatives, and the only problem area would be the axle weight?? Does anyone know?
thanks a lot!
Prob be OK on the smaller lumps if TA have spec'd the springs for all engines. The 2.4 and 3.2 are a bit heavier mind you so it must be compromised in some way. That said the TA coilovers ive used on x2 other cars were fine.
I think H&R do the drop your looking for don't they?
1 - 2 of 2 Posts
