Can anyone tell me if t-cut, does any harm to a vela blue 156, I have small hairline scratches and the normal car wash swirls. Will this help along with a good polish ?
It won't do any damage but it probably won't do any good either, there's better polishes out there.All pretty well covered in this section.
There are MUCH better products available in the UK. Check out Meguiars, Autoglym, Chemical Guys.
Look at cleanyourcar.co.uk for a good range, tips, and even it's own forum.
For light scratches, I really would point you in the direction of Autoglym Paint Renovator.
T-Cut is a last-resort for areas that you don't really notice, IMHO.
I have used T cut on may cars over the years with pretty good results. Just make sure you get the metallic version.
There may well be better products around now, but T cut is well proven over the years.
If you have very hairline scratches you could use a good polish....if they are a bit worse than that try Turtlewax safecut.
'T' cut was the 'after' Farcla cutting/levelling paste, and then Harris's burnishing. All abrasive, with varying degrees of cut and finish. Obviously the finer the polshing abrasive, the higher the eventual shine. I finish with Zymol, and then just flit over with silicone polish, on a micofibre to keep it sparkling. There are plenty of products out there, some extortionately costly imo. So although I know many disagree with my methods, I don't! Bit swell headed maybe, but the shine is Fine.:lol:
