1 - 2 of 2 Posts
· Registered
I have had my Speedline split rim wheels renovated they look great but one of the rears is not sealing properly.
Any idea if the split rims seals are available at all or if there is an alternative available otherwise I guess it is a case of squirting a sealant in instead.
Thanks Paul
· Registered
As far as I understand, the seals are not available. For a replacement, you could look to the aviation buisiness, there split wheels are common, and the seals are replaced at every tire change. It's just a matter of finding the right size...
What you also could check, is if the affected seal is still ok. I mean, it is not damaged, cut or split. If it is just a bit deformed, maybe some vaseline on the seal will help. Otherwise, sealant is the way to go...
1 - 2 of 2 Posts
